How to integrate TeamCity with StresStimulus
abhishek Posts: 4
3/21/2018
I have created a loadtest using StresStimulus. The ssconfig file is placed at a remote machine. I am able to login to this machine and run the test using command line.
Now, this machine can be accessed by TeamCity (CICD tool). I have configured the CMD command in the TeamCity as I want to execute the load test through TeamCity.
When TeamCity triggers the command, it throws an error. It says, the UI is unable to handle.
Could someone please suggest.
George @StresStimulus Administrator Posts: 555
3/21/2018
When you launch StresStimulus from a remote machine, the UI cannot work under the remote user context. To fix it, you need to run StresStimulus in console mode (no UI).
Use the /noui flag when launching StresStimulus through command line http://support.stresstimulus.com/display/doc49/Command+line+interface+for+Standalone+version
This feature was added in v 4.9 beta that is available https://www.stresstimulus.com/download
abhishek Posts: 4
3/22/2018
Thanks very much for your response. It works fine with the mentioned solution.
3/22/2018
Abhishek,
Thank you for sharing your update.
-Cheers
