Execution and actual processing of SalesOrders
Suvanta Posts: 2
3/29/2024
I am using Stress Stimulus to do load testing on Dynamics 365 Finance &Operation I have created all parameters for execution of sales order. Even after Correctly parameterizing it , the actual execution of the data is not happening while executing the test scripts with multiple VU's what has to be done for this and test summary shows no errors and Iteration and transactions are passed
George @StresStimulus Administrator Posts: 555
4/2/2024
As I understand, you have correctly created all the parameters necessary for your scenario and testing requirements. However, if your script execution with a single user fails on the first iteration, it is evidence that your script is missing correlation parameters. To address that, you need to add to your script manual correlation as follows: You do not see errors in your test report because Dynamics 365 Finance & Operation does not automatically send HTTP errors when it encounters application errors. Therefore, you need to create validators to check specific transactions for errors as described: https://support.stresstimulus.com/display/doc59/Response+Validators.
If you need our assistance to fix your script, then: - Cheers
