Dynamic Regex Extractor does not work in Verify
swalker Posts: 1
10/6/2022
Hi all,
We are working on the https://challenge.flood.io script in SS and I decided to use a dynamic regular expression extractor to pull the "Largest Order" value.
We are able to craft the regex and it works in Edit Extractor verify, however when we verify the script it does not work.
Here is my first extractor regex and second dynamic regex extractor
C_largest_order= largest_order=(.*?);
C_Challenger_order_selected= value="{{C_largest_order}}" \/><label class="collection_radio_buttons" for="challenger_order_selected_.*?">(\d+)<
I will attach some screen captures of the script below.
George @StresStimulus Administrator Posts: 556
10/6/2022
I successfully recorded and playback a script from the website above. Here are a couple of suggestions: - Make sure you use the latest StresStimulus version (currently v 5.6.8314)
- Set the "Use URL decoding?" property of the C_largest_order extractor to Yes. Not setting this property can cause sporadic errors.
Also, wanted to give you a heads-up that you would need to create a few parameters required by this scenario. I have not described them here since I was unsure if you want to complete the script by yourself for learning purposes. But if you come across any questions, please feel free to post them here, and we will assist you. - Cheers
