Cookie Management
Unregistered User Posts: 509
6/1/2023
I’d like to know more about how StresStimulus handles cookies. My goal is to setup a configuration, that allows virtual users to have their own cookie container. Each cookie should be reused for every iteration. So for a test run with 4 VU and 4 Iterations, 4 Cookies should be set overall. Is this the default behavior of StresStimulus? If not, which steps should be taken?
George @StresStimulus Administrator Posts: 556
6/1/2023
By default, cookies are correlated and reused automatically on subsequent iterations as described https://support.stresstimulus.com/display/doc57/Test+Case%3A+Session+Persistence. You can find more information on how StresStimulus handles request cookies and correlation from https://support.stresstimulus.com/display/doc57/Cookie+correlation and https://support.stresstimulus.com/display/doc57/Cookies+to+send
