A list of XML collections, elements, attributes and corresponding UI properties is provided below.
Collection <TestCases>
Element TestCase
XML Attribute
UI Property
Description or Values
When Used
Name
Name
The Test Case name.
MixWeight
Mix Weight
The relative frequency of the Test Case replays in the mix. Every VU is assigned to a specific Test Case selected in a round-robin order, while skipping some of them to achieve the VU distribution corresponding to the mix weights.
Description
Description
The Test Case description.
ThinkTimeMode
Think Times between pages
0 - Zero; 1- Recorded; 2 - Constant; 3 - Random
ConstantThinkTime
Think Time (s)
A constant think time between pages.
ThinkTimeMode = 2 (Constant)
MinRandomThinkTime
Min Think Time (s)
ThinkTimeMode = 3 (Random)
MaxRandomThinkTime
Man Think Time (s)
IterationDelayMode
Delay between iterations
0 - Zero; 1 - Constant; 2 - Pacing
ConstantDelayTime
Iteration Delay (s)
A constant delay between iterations
IterationDelayMode = 1 (Constant)
MinIterationDuration
Minimum iteration duration (s)
the minimum iteration duration. If the iteration completes faster, the appropriate delay will be added.
IterationDelayMode = 2 (Pacing)
CacheControlMode
Cache Control
0 - Disabled; 1-Enabled
NewVuPercent
New VU %
Percentage of the New vs. Returning VUs.
CacheControlMode - 1 (enabled)
RestarBßrowserPercent
VU restarting browsers %
Percentage of VUs restarting browsers before starting new iteration.
Collection <Transactions>
Element Transaction
XML Attribute
UI Property
Name
Name
The Transaction name
Description
Description
The Transaction description.
GoalTime
Goal (s)
The transaction's completion time limit
TestCase
Test Case Name
StartSession
Zero-based first session number
EndSession
Zero-based last session number
Element Authentication
XML Attribute
UI Property
CredentialFile
A name of the CSV file with 3 columns (domain, username, and password) and no header
Element DataSources
XML Attribute
UI Property
<dataset name 1>
A Dataset CSV file with a header
| <dataset name n> |
A Dataset CSV file with a header |
Collection <DataGenerators>
Element DataGenerator
XML Attribute
UI Property
When Used
Name
Name
The Data Generator name
DataGeneratorType
0 - Integer, 1 - Double, 3- DateTime, 4 - Guid, 5 - Text
MinValue
MinValue
The minimum generated value
DataGeneratorType="0" (Text), "1" (Double), "3" (DateTime,)
MaxValue
MaxValue
The maximum generated value
FormatString
FormatString
A string specifying a format of presenting a value. For details about different data type Formats, check "Formatting Types" in .NET
Description
Description
The Data Generator description
MinLength
MinLength
The minimum number of characters in the generated word
DataGeneratorType="4" (Text)
MaxLength
MaxLength
The maximum number of characters in the generated word
Collection <Functions>
Element Function
XML Attribute
UI Property
| Name |
Name |
The Instance name |
| FunctionType |
0 - AgentName, 1 - AgentVUNumber, 2 - TestCaseName, 3 - AgentIterationNumber, 4 - URLNumber, 5 - AgentRequestNumber; 6 - CurrentDateTime. |
| FormatString |
FormatString |
A string specifying a format of presenting a value. For details about different data type Formats, check "Formatting Types" in .NET |
| Description |
Description |
The Function Instance description |
Collection <Extractors>
Element Extractor
XML Attribute
UI Property
When Used
Name
Name
The Extractor and its variable name.
ExtractorType
0 - Text Delimited, 1 - Regular Expression, 2 - Header, 3-FormField, 4-XPath
TextBefore
Text Before
A text delimiter that occurs immediately before the value to be extracted.
ExtractionRuleType = 0 (Text Delimited)
TextAfter
Text After
A text delimiter that occurs immediately after the value to be extracted.
RegEx
Regular Expression
The regular expression with a single value <val> which will be extracted.
ExtractionRuleType = 1 (Regular Expression)
Header
Header
The response header name, selected from the drop-down
ExtractionRuleType = 2 (Header)
FormField
Form Field
The form field name, selected from the drop-down
ExtractionRuleType = 3 (FormField)
Xpath
XPath query
Enter XPath query to extracts a value from a web service XML response
ExtractionRuleType = 4 (Xpath)
Occurrence
Occurrence
The occurrence of the matching text to be extracted. The default is 1.
IsHtmlDecode
Use HTML Decoding
0 - No, 1 - yes
TestCase
Test Case Name
Session
Zero-based session number
Description
Description
The Extractor description
Collection <Parameters>
Element Parameter
XML Attribute
UI Property
When Used
ParameterNumber
zero-based parameter number in the request
RequestPart
1- QueryString, 2 - Form, 4 - Header
TestCase
Test Case Name
Session
Source
0 - Static, 1 - DataSet, 2 - Extractor, 3 - Data Generator, 4 - Function
DataSet
DataSet
Source = 1 (DataSet) |
DataBinding
0 - Sequential, 1 - Random, 2- VU_Bound
DataField
DataField
Extractor
Extractor name
Source = 2 (Extractor) |
DataGenerator
DataGenerator name
Source = 3 ( Data Generator)
Function
Function name
Source = 4 ( Function)
Collection <Validators>
Element Validator
XML Attribute
UI Property
Text
Text to search
Text/HTML or regular expression to search for in the response.
IsRegex
Is text a regular expression?
0 - No, 1 - Yes
FailIf
Fail If
0 - Found, 1 - Not Found
Scope
Scope
0 - Response, 1 - All Responses
Description
Description
The Validator description
TestCase
Test Case Name
Session
Collection <Agents>
Element Agent
XML Attribute
UI Property
Name
Agent Name
The Load Agent Name
Host
Host / IP Address
The Load Agent Host
UserName
Username
Username to access Remote Agent
Password
Password
Password to access Remote Agent
MixWeight
Mix Weight
Relative number of VUs emulated on the Load Agent.
StartingThreads
Starting thread count
The number of threads created automatically on the agent when test is launched.
Element Test
XML Attribute
UI Property
When Used
| TestID |
| TestDescription |
Test Description |
Test Description is included into the Summary report. |
| NextRunName |
Test Run Name |
A one-word Test Run Name is used as a prefix to label the result set of the next test run, displayed in the "Previous Results" section. If the Test Run Name is empty, the test file name and a timestamp is used as the prefix. |
| LoadPattern |
Load Pattern |
0 - Steady Load, 1 - Step Load |
| ConstantVU |
Number of VU |
The constant number of VUs emulated throughout the test |
| StartVU |
Start VU |
The initial number of VUs in the beginning of the test |
| StepVUIncrease |
Step VU Increase |
The number of VUs added on every step |
| StepDuration |
Step Duration (s) |
The time interval between increasing VU count |
| MaxVU |
Max VU |
Maximum VU count - Note: Test can complete before reaching "Max VU" if the Test Duration is not long enough. |
| IncreaseOver |
Over (s) |
The amount of time taken in the beginning of each step to gradually add VUs. For instant increase, use zero. |
| TestDurationMode |
Test Completion Criteria |
0 - Number of Iterations, 1-Run Duration, 2 - Reaching max VUs |
| IterationCountMode |
How to count iterations |
0 - Total , 1-Per VU |
TestDurationMode = 0 (Number of Iterations) |
| Iterations |
Max. iterations |
After the specified number of iterations is issued, the Test waits until all responses are received and stops. |
| LoadTime |
Load generation time (hh:mm:ss) |
The duration of load generation, after which no request will be issued. |
TestDurationMode = 1 (Run Duration) |
| AfterTimeElapsedMode |
After the time elapsed
0 - Wait for responses, 1 - Stop the test |
| WarmupTime |
Warm-up time (s) |
The warm-up period at the beginning of the test is necessary to prepare server for normal working conditions |
TestDurationMode = 1 (Run Duration) or TestDurationMode = 2 (Reaching max VUs) |
| ResultStorageMode |
How much data to store |
0 - All, 1 - Partial, 2 - None |
| DataStorageMedium |
Data Storage |
0 - Embedded SQL Server CE, 1 - SQL Server |
ResultStorageMode = 0 or 1 |
| ConnectionString |
SQL Server connection string |
ResultStorageMode = 1 |
| PurgeRequestBodyMode |
Purge request bodies |
0 - Non-Errors, 1 - All, 2 - None |
PurgeResponseBodyMode
Purge response bodies |
| GraphSampleTime |
Graph sample rate (s) |
How often the performance counters are read and graph are refreshed. Recommended value is 10s with agents and 5s without the agents. Increase "Sample Rate" for long tests. |
| AgentPollingTime |
Agent sample rate (s) |
Enter how often the remote agents are polled. Cannot exceed Graph sample rate. Recommended value is 10s. Increase it for long tests. |
| DefaultPageTimeout |
Default Timeout (s) |
The maximum amount of time for receiving any of the page requests. A page timeout error is triggered if any of the page sessions' response times exceeds the Timeout. |
Collection <BrowserCollection>
Element item
XML Attribute
UI Property
When Used
| BrowserId |
Browser Type |
| MixWeight |
Mix Weight |
Relative frequency of using this browser by VUs. |
| MaxHostConnectons |
Connection limit per host |
The maximum number of TCP connections per host. |
| MaxProxyConnections |
Connection limit per proxy |
The maximum number of TCP connections across all hosts. |
| ReplaceUserAgent |
Replace User-Agent string |
True, False |
| UserAgentString |
User Agent
Custom User Agent |
ReplaceUserAgent = True |
Collection <NetworkCollection>
Element item
XML Attribute
UI Property
NetworkID
Network Type
MixWeight
Mix Weight
Relative frequency of using this network by Vus
UploadBandwith
Upload Bandwidth (kbps)
DownloadBandwith
Download Bandwidth (kbps)
