More options for test duration and longer tests in new release
A new StresStimulus version released today includes two updates:
  1. Extended  test duration cap to one hour.
  2. Added choice  for tests  with fixed Run Duration to either:
  3. -  continue test past run duration time until all responses are received;
  4. - OR stop test once run duration time is reached and ignore sent requests;
The latter choice is helpful when precise test duration is required. For example,  for comparing two tests that should have the same duration.
All known bugs including ViewState autocorrelation bug, causing in some cases server errors, are fixed. So if you forwarded a bug report to us, be sure it is fixed.
To new version is available here.
